40T brake shaft seals
DK IN WI
10-02-2007 15:57:37
I am considering pulling the rear axles and housings off of my 40T to try an stop minor leaks. The axle seals, brake seals, and gaskets for both sides come to about 130$- so cost isn't horrible. I was just wondering if anyone has any tips on how terrible or easy this job is. I would like to restore this tractor completely from end to end, but if this is a big pain, I don't think it really needs it-just scared of any hidden troubles a novice should stay away from. THANKS
Jason Mills
10-03-2007 05:38:53
 Re: 40T brake shaft seals in reply to DK IN WI, 10-02-2007 15:57:37
The final drives will have to removed from tractor in order to replace seals. Be sure to properly support machine when removing drive. I recommend doing one side at a time. This helps to keep tractor fairly stable while removing drive. The seal on the brake shaft is not one of Deere's better ideas, but the one you have is probably original for the machine, fifty plus years old. The bullgear will have to be removed after you get final drive off to change brake shaft seal. Be sure to check pinion bearings while you have drives off. Mine were worn out so I replaced them while I was there. If you have a floor jack and a engine picker, then you are halfway there. The other half is a little time and patience. Good luck with your project, Jason.
Mike M
10-03-2007 04:48:29
Just get a service manual to help guide you through it. Nothing on those models is going to be that hard to do. Sounds like the perfect time to get the brakes in top working order and stop the other leaks too. I feel brakes are important!
