There is a 9650 ten feet away from where I'm standing. It has the same problem, only much worse. It refuses to start after sitting only two days. There have been a ton of modifications done to these things. Trying to give specific help on a message board probably isn't going to help much. Because with all the "updates" that may or may not have been installed, I still haven't seen ONE of these machines yet that is assembled according to the parts catalog. Here's one thing you might try: IF there is one of those 1/4 turn ball type shut off valves on the bottom of the tank, try closing it right away the next time you shut off the engine. - Just REMEMBER to turn it on again the next time you want to start it. If it starts OK, look around all the fuel hoses and filters. No leaks are a must. Not even a damp area. The design of this system pretty much guarantees you aren't going to fix much without "throwing parts at it". {that's blasphemy to us old school guys} So what I'm saying is that if you don't see anything obvious, prepare yourself for $$$....Or live with it....Or trade it off and let the next guy worry about it, like the one behind me.
