HARD STARTING 4440
CALLAHAN
10-01-2007 19:44:28
I HAVE AN 82 4440 JD AND SOMETIMES I HAVE TO CRANK IT OVER FOR MINUTES FOR IT TO START TEMP HAS NO BEARING AT ALL ANY HELP THANKS
buickanddeere
10-02-2007 22:03:29
 Re: HARD STARTING 4440 in reply to CALLAHAN, 10-01-2007 19:44:28
Don't crank it for minutes. Not only will you still have to pay for injection pump repairs. There will also be a bill for at least a starter/solenoid.And very possibly cables, batteries & the alternator.
JMS/MN
10-01-2007 23:39:44
Other poster mentions the aneroid thing- my 4430 has that, and if I kill it in the field, I can crank till ....freezes over, without starting. But lean over the hood, flip the 'toggle' thing on the aneroid, and it starts right off. Also, a diesel shop mentioned something about washers to put under the injectors to improve starting. 44s are cold starters.
wilamayb
10-01-2007 20:24:44
Does it do this non-starting thing as soon as you cut it off, or does it require that it sits for a while before it starts? If it does it regardless of sit time I would suggest that you may have a problem with your hyd. aneroid on you inj. pump. If sitting for a while causes the hard start you could have other injection pump problems.
This is all said assuming that the engine is turning over well. Check those batteries, make sure the cables are adequate size and are clean. You need to have a good ground. What about your starter motor? Has it been serviced in years?
Just a few things to consider.
jd2140
10-01-2007 20:10:49
well you could try a distroker in the hydraulic pump, it will cut the pump off while you are cranking it, then unscrew it after the tractor fires and it cuts it back on, how fast is the tractor turning over? If your starter is dragging that will cause one to not want to start good.
