430 knock in engine
Roger in Michig
10-01-2007 16:06:03
Got a 430W that has a knock. I don"t think it"s rods, mains, or piston pins. I"
m not an expert mechanic but have it apart and those things look real good. What is the next most likely possibility?
Cam bushings? Or something else.
Thanks,
Roger
Green Relics
10-03-2007 05:27:23
 Re: 430 knock in engine in reply to Roger in Michigan, 10-01-2007 16:06:03
Hey Roger, An engine with a true knock should not be to hard to find. In order to knock it's usually a spun rod bearing resulting in a really roughed up crank journal. I seen some much lighter sounding knocking from bad rod bushings, but they have to be really worn. Also some light noise can be made by really worn pistons "slapping" in the block. Now that it's torn down any of these issues should be quite obvious. I usually would have looked at all other ways to eliminate the noise before teardown like taking off fanbelt to eliminate waterpump, generator etc. Did it make noise with clutch held down, that eliminates any transmission noise vibrating up thru drive line. Unfortunately your probably going to have to put her back together and start searching again if the engine rebuild doesn't work. John
Roger in Michigan
10-03-2007 08:33:16
 Re: 430 knock in engine in reply to Green Relics, 10-03-2007 05:27:23
Thanks, Green Relics.
I don't have the shop manual, just the IT manual. It doesn't give tolerances for cylinder bore wear or piston skirt wear. Do you know how much is too much wear?
Wrist pins are nice and tight.
No change with clutch held down.
Also, the knock follows the rhythm of the engine revolutions precisely. This would seem to eliminate water pump, don't you think?
Thanks
Roger
machinery-man
10-02-2007 12:12:09
Roger: This stumps me..other than warming up, noise tends to subside...tells me heat/expansion taking care of clearance...busted piston skit? Doesn"t sound like rod bearing as it should be getting louder as oil thins...have you checked for a cracked crankshaft, maybe in a main bearing? Sorry can"t be of more help....
Roger in Michigan
10-02-2007 13:22:43
 Re: 430 knock in engine in reply to machinery-man, 10-02-2007 12:12:09
Thanks,machinery-man and all others. I guess I'll have to keep on working on it. I'll post again when I find out what the problem is. It might be a while.
Thanks again for the help.
Roger
Dave H
10-02-2007 04:31:34
Roger
do you know what the clearances are on the new bearings? New bearing inserts won't fix a worn out crank throw or main bearing.
machinery-man
10-01-2007 16:53:34
Personally I would mike the parts you have just described to make sure. I would also suspect a thrust main bearing. Its hard to know but I would think this would produce a thud...you may have had a timing problem which would be a bummer since you tore the engine down...
Roger in Michigan
10-01-2007 17:31:43
 Re: 430 knock in engine in reply to machinery-man, 10-01-2007 16:53:34
machinery-man,thanks for the reply. I have replaced the main bearings. I also adjusted the timing prior to tear-down. The knock happens mostly when I give it more throttle. Seems less once rpm levels off. It gets less when the engine gets warm. Does this help?
Will P
10-01-2007 20:27:55
 Re: 430 knock in engine in reply to Roger in Michigan, 10-01-2007 17:31:43
Like 430WLPG said. Look at the wrist pin area. Wore wrist pin bushing or the piston pin hole. I know my G is different than the 430, but it did the same thing as you describe. The bushing was shot.
Will
430WLPG
10-01-2007 17:50:50
Look at the piston pin holes closely. I have also seen the governor flyweights loose enough to slap the block
