Unstyled B: Coolant Leak Question
Bguy
10-01-2007 09:50:38
I have an unstyled B that starts and runs great but after it sits for a couple of weeks it will blow and leak coolant out of the exhaust when started (makes a mess). It must be a very small leak because it has to sit for at least that long for the problem to show up. There is no water in the oil or oil/bubbles in the radiator that I can see. After it runs for a few minutes the water burns out of the cylinder, manifold, exhaust and there is no further sign of the problem. It seems that it would almost have to be a head gasket but I wanted to throw it out here for discussion before I tore into it. What do you think?
DickD
10-01-2007 21:23:44
 Re: Unstyled B: Coolant Leak Question in reply to Bguy, 10-01-2007 09:50:38
Sounds to me like xragman hit the nail on the head. Pushrods are a very common cause of the very thing you are talking about.
Mike M
10-02-2007 05:09:06
 Re: Unstyled B: Coolant Leak Question in reply to DickD, 10-01-2007 21:23:44
Push rod tubes leaking coolant into the cylinders and getting blowed out the exhaust ????? Please tell me how that is possible ?
Push rod tubes will leak coolant into the engine oil and fill up the crankcase.
Gary from Muleshoe
10-01-2007 15:39:52
Bguy
I have a 1940 with the same type of cooling system. I had a small leak that would leak onto the tires. I put some Bars Leak just before a long parade and it sealed it right up. They do have to run a long time to get then hot enough to circulate the coolant. If you have a way to work it hard that would be better. If nothing else just drag a dead weight around for a bit to get it warmed up good.
xragman
10-01-2007 12:33:46
Probly the push rod tubes thru head leaking some. Did you change them during overhaul ??
Bguy
10-01-2007 12:05:16
Thanks for the replys. I have retorqued the head a couple of times and it didn't seem to make any difference. I thought about using a stop leak product put I don't see how that could work in a thermo-syphon system. Doesn't it need the pressure to push the particles down into the voids to form a seal? Seems like the stuff would just slosh around in there without pressure. It may be that the block needs to be decked, the head was decked when I rebuilt it. Looks like I need to go on and order a new head gasket and pull the head and check it out.
Thanks Guys
Mike M
10-01-2007 12:30:35
 Re: Unstyled B: Coolant Leak Question in reply to Bguy, 10-01-2007 12:05:16
The stop leak can work but your right a system under pressure and circulating will work better.
I have a late B that had the head redone and surfaced,block checked maybe redone ? new gasket,head retorqued but it still wanted to seap antifreeze out along the top to the outside when it sat for awhile. These metal sandwich gaskets are not the greatest in my opinion. The older ones with asbestos in them sealed better. The change over material is harder and doesn't seem to seal as good.Plus they used to overlap + crimp the coolant passages which would let them seal better when tightened,but on these late B's the top overlap part sometimes doesn't match up and doesn't get crimped tighter even on the ones where they were made with that area in an overlap crimp.
I put Bar's Leak in my B right before a tractor show where I was able to go do some plowing and that was all it took to seal it up. No more seapage.
But I also knew what it was. No cracks and a NEW gasket. You could have a crack ? or a bad gasket ?
The stop leak won't hurt anything so you don't have anything to loose.
JD@Antique Acres
10-01-2007 10:15:20
It could be a simple as the head gasket. But it could also be that you have a slight imperfection in the head or the block that the gasket would not seal. I had this on an A once and had the block AND the head both milled true and it solved the problem.
Mike M
10-01-2007 10:09:47
Have you tried retorqueing the head ?
If you really don't want to tear it apart put some Bar's Leak in it and go work it hard. It will take more than a small can and it will take more than just driving around as you have no water pump to circulate it.
