4440 losing power
Tom P
10-01-2007 09:03:59
I plowed most of the day with a 4440 this past weekend. It almost seemed as if I got into some tougher ground, but then realized I was losing power. Not allot, but enough to have to drop a gear. Coolant temp was fine, oil pressure good, no mechanical noises. After about 10 minutes the problem got worse. If I would stop and idle it down and restart, it would go again for a few hundred feet before dropping again. It almost seemed to be dropping a cylinder or two. Now when I go to start is it barely fires up and then stalls. By touching the exhaust manifold, the first three cylinders are cold while the back three seem to be firing. I'm going to try new fuel filters first. Just wondering if anyone has a heads-up for anything else to look at?? The tractor has about 6000 hours, and as far as I know the pump has never been rebuilt or worked on.
TractormanNC
10-01-2007 18:42:28
 Re: 4440 losing power in reply to Tom P, 10-01-2007 09:03:59
Have a 4240 that did about the same thing. The standpipe on the fuel tank valve had about 1/2 inchof crud in it. Was also sucking air through the packing around the valve stem. Might check this
buickanddeere
10-01-2007 18:42:08
Check flow & pressure up to the injection pump, just don't change the filters. There could be a tank or line obstruction. Even a weak low pressure pump.
JMS/MN
10-01-2007 09:54:21
Don't forget the air cleaner.
Tom P
10-01-2007 19:51:01
 Re: 4440 losing power in reply to JMS/MN, 10-01-2007 09:54:21
It was the air cleaner, the inner air cleaner. The outer one had been replaced several times over the years, but apparently the inner was still the orginal and there must have been dirt flowing through the primary filter.
