36 B main bearing and crankshaft problems
J Boshears
10-01-2007 08:44:49
I just removed the crankshaft from my 36 B the rod and main journals need to be repaired. There is a crankshaft repair shop close to where I live who can weld and grind cranks. But my big problem is the main bearings themselves. I looked at the bearing halves and the babbitt is cracked very badly and some of it fell off when I removed them. John Deere wants $200.00 for the right side bearing and said the left bearing is obselete. What should I do?
kendak
10-02-2007 17:30:18
 Re: 36 B main bearing and crankshaft problems in reply to J Boshears, 10-01-2007 08:44:49
I'm using main bearing housing & insert type bearings off 46 model on my 37 unstyled ..bolt on operation ...Kent
kendak
10-02-2007 17:35:57
 Re: 36 B main bearing and crankshaft problems in reply to kendak, 10-02-2007 17:30:18
sorry misread post thats for an "A" model...just got out of hospital not thinking at all...Kent
P Browning
10-01-2007 10:37:22
Give Russ a call @ Paul;'s Rod & Bearing AKA Heartland Tractor Parts; 816-587-4747. Well knowledgeable and easy to talk with -- can lead you through the alternatives! (PatB)
Mike M
10-01-2007 10:14:27
There are some places that are redoing those. I think ? Check in green mag or 2 cyl mag for an ad.
It's likely to be alot cheaper to find a good used crank and get the bearings with it.
