Installing Mag impulse spring
JBiff76
09-30-2007 05:33:04
When installing a new impulse spring in a Fairbanks Morse type FMJ mag, how tight do I tighten the impulse lock nut? If I tighten it to where it feels tight enough to stay on, the mag will not turn over properly or at all. If I loosen the nut up for it to turn/snap properly it doesn't seem like the nut is tight enough to stay tight. Thanks in advance, Jon B.
teddy52food
09-30-2007 16:43:53
 Re: Installing Mag impulse spring in reply to JBiff76, 09-30-2007 05:33:04
The inside end of the spring has to be in the deepest slot in the hub. You should be able to torque up the nut and still turn free if it is together right.
DaveS
09-30-2007 07:57:07
It needs to be pretty snug. I've worked on some that the cotter pin was gone. If it is making everything bind up when you tighten it, something is not put together right.
