730 Float level
motorstuff
09-29-2007 18:30:55
I removed the fuel drain cock and installed a brass fitting with a 1/4" clear hose. How high should the gas level be in the bowl measured from the bowl gasket? I am worried it will leak or flood if it is close to or above the gasket.
Thanks,
Mike
Mike Aylward
10-01-2007 04:57:43
 Re: 730 Float level in reply to motorstuff, 09-29-2007 18:30:55
If memory serves me right the 3/4" dimension is for the float itself. This is measured from the gasket surface. This gives a fuel level of right at the gasket. Hope this helps. Mike
motorstuff
10-01-2007 19:26:12
 Re: 730 Float level in reply to Mike Aylward, 10-01-2007 04:57:43
Thanks for the replys. Is it correct for the fuel level be right at the gasket when I check the level using the plastic tube?
bigblock
09-30-2007 15:22:10
3/4 under I believe.But make sure the needle and seat are sealing.Mine seeps a little and the plug in the bowl is stuck so I cant tell where it is exactly.
