portable generator probs???
ike eidenschink
09-29-2007 17:00:17
i'm a deere guy but need some good practical advice o;k i have a nice 5 h.p. 2500 watt generator 4 year old i use at my hunting/fishing shack all of a sudden it decides to only put out 6 volts it is a brushless type induces into rotor etc i changed the diodes on the rotor windings no help tried shooting some d,c, into the stator windings still only 6 v a, c, out anyone got some ideas heck it isn;t worth taking to a dealer etc, us deere guys must have an idea or 2 o;k thank you very much mt guy here back in mn.
mt guy
10-09-2007 20:16:57
 Re: portable generator probs??? in reply to ike eidenschink, 09-29-2007 17:00:17
changed the caps still only 4.5 a.c. out ??? shorted winding???
mt guy
10-09-2007 20:14:25
was at camp over week end did the cap replace still only 4.5 a.c. out guess she is ready for retirment and use the motor on a log splitter
NE IA Dave
10-01-2007 18:14:41
 ANYONE REMEMBER THE SIMPLE FIX? in reply to ike eidenschink, 09-29-2007 17:00:17
I ainy had much school housin, but didn't some one suggest in March or so of this year to just spin a drill backwards while holding the trigger down. Sorry I can not remember the details, but it was a very simple fix with alot of agreement if I recal correct. I am sure it was on a YT board.
ike eidenschink
09-29-2007 23:14:47
i didn't replace the lil blue cap seemed o'k when did a test omhs will try it also yah i did into rotor with 6 volt d.c ?? did twelve volt d.c, to flash stator also 120 to flash it too still only 6 out
buickanddeere
09-30-2007 18:20:18
 Re: portable generator probs??? in reply to ike eidenschink, 09-29-2007 23:14:47
What did the cap test with an ohm meter? Digital meter or analog? Initial reading and after 5 seconds?
buickanddeere
09-29-2007 22:06:31
The rotor will have to come out and the leads going into the rectifier/regulator energized with probably 120vac for testing purposes. What voltage and is it AC or DC is it measured being applied to those exciter windings? What is the current measured going in one excitor winding end and out the other? As you may suspect. Finding an entire new generator or a new generator head for the existing engine are the likely solutions. I just can't get real keen on a brushless generator.
Bob
09-29-2007 22:00:41
A while back, someone on one of these Boards was having a similar problem, and it turned out there was a little 'lytic "cap" tucked in near the diodes. He replaced the "cap", and was back in business. Any chance your's has a "cap", as well?
If NOT, likely a winding has shorted.
