1969 John Deere 4520 Overheating
Bruce G
09-28-2007 22:04:38
I have a 1969 4520 which overheats under load. The radiator, water pump, thermostat have been replaced but it still runs at the red line and the radiator water is boiling pulling a disk. I don't even want to know what it would do with a plow. I assumed the water pump, thermostat, and gauge are not at fault since the coolant is boiling and blowing out the overflow. Could this be caused by the turbocharger, aftercooling, timing, or something similar not working right? Most of my knowledge is with gasoline engines and I know almost nothing about turbo charged diesels.
MSM
09-29-2007 11:21:11
 Re: 1969 John Deere 4520 Overheating in reply to Bruce G, 09-28-2007 22:04:38
Are you running coolant,or just water? Plain water will boil,and cause corrosion which will clog the radiator quickly. A 50-50 mix of coolant will not boil until 230+if the pressure cap is good. Is the air filter clean,or has the tractor been turned up? Are you getting bubbles in the radiator,a cracked head,leaky headgasket will let compression escape into the cooling system giving you the results you describe also.
Bruce G
09-29-2007 19:23:06
 Re: 1969 John Deere 4520 Overheating in reply to MSM, 09-29-2007 11:21:11
The radiator has coolant in it, not just water, the fan blows the right way and moves a lot of air, The engine was overhauled 2 years ago and the head replaced but the overheating problem was happening before then from what I am told. The only things I can think of are the muffler started to go out and that might have reduced the back pressure powering the turbocharger making the engine work too hard. Also, they have me pulling a 16' disk in clay soil in 4th gear at 2100 rpm. From what I can tell, with 107 drawbar HP the disk is too large and the speed is 7.5mph instead of the recommended 6mph. Does any of this sound reasonable?
msb
09-29-2007 07:28:17
Think I would pull the radiator and have it flow tested. The 4520 had one of the very best cooling systems Deere ever built.
Tech 7
09-29-2007 06:12:42
This may be a shot in the dark but is the fan installed the right way on the hub? Yes it will fit,yes it will move air,but not enough to bring the coolant temp down. Good luck, Bob
lonzo
09-28-2007 23:25:24
take a peak see at the crank shaft pully and water pump pully and see if the gruves are worn down on the sides
greg tura
09-30-2007 05:45:07
 Re: 1969 John Deere 4520 Overheating in reply to lonzo, 09-28-2007 23:25:24
Try removing thermo completely. The coolant will circulate continuosly. Although. it may not reach operating temp but,it may not overheat... JAT (just a thought)..... ..... .greg
