2020 dies under load
gumbah
09-28-2007 13:16:42
I have a 2020 that will crank only on choke. Then with the tractor in neutral, as you increase the power at about 2/3 throttle the engine will cut off just like you turned the key off. We changed the electric fuel shut-off on the carb. We dismantled and cleaned carb 3 times. Replaced the points, condensor. Tried a new coil. Loosened the fuel lines and blew air through them including back into the tank. Cleaned the inline filter. Loosened the line at the carburator and turned the engine over, gas shot out everytime the fuel pump pumped. What is the problem? We are beyond puzzled.
Gerald J.
09-28-2007 14:00:52
 Re: 2020 dies under load in reply to gumbah, 09-28-2007 13:16:42
Pull the carburetor inlet adaptor. It has a screen and from experience (with a 2020 and others) I lay good odds that the screen is plugged. My neighbor's wouldn't pass detectable air at 60 psi. Deere didn't have a spare so ran a drill through it. Then the tractor ran fine.
Gerald J.
