2555 JOHNDEERE
JON GILLESPIE
09-28-2007 08:23:14
I JUST BOUGHT ONE AND THE TACH IS NOT WORKING ALL OTHER LIGHTS AND GAUGES SEEM TO BE FINE. THIS IS AN ELECTRICAL TACH. WHAT DO YOU THINK COULD BE WRONG AND WHERE SHOULD I START LOOKING. THE GUY SAID IT WORKS FROM TIME TO TIME BUT NOT ALL THE TIME
ben brown
09-28-2007 17:45:56
 Re: 2555 JOHNDEERE in reply to JON GILLESPIE, 09-28-2007 08:23:14
ON 50 AND THE 55 series you well find the tack sending unit in front cover of engine reach behind alt. some time the wire comes loes thies are magnatic sender held in by to small bolts takes a 10 mm wrench to remove
JON GILLESPIE
10-02-2007 05:22:48
 Re: 2555 JOHNDEERE in reply to ben brown, 09-28-2007 17:45:56
THANKS FOR THE RESPONSE I CHECKED ALL CONECTIONS ON ALTENATOR AND SEEMED GOOD. I DID SEE THAT MOUNTED ON THE VERY FRONT OF TRACTOR AND PULLED THAT CONNECTION OFF BUT DID NOT KNOW WHAT IT WAS. I THINK THAT WIRE GOES FROM THERE TO ALTENATOR. I DONT HAVE MY MANUAL YET SO IAM IN THE DARK ON THIS STUFF.
buickanddeere
09-28-2007 08:51:58
The tach is driven from a terminal on the Bosch alternator. If the alternator is ok, then the wiring, connections or tach are at fault. I did wind my 1640's tach to the limit when setting up the fast idle speed for a long road trip.The tach didn't read for a while, then later indicated rpms lower than actual. If seemed to re-set after it was powered down for a while.
JON GILLESPIE
09-28-2007 08:56:35
 Re: 2555 JOHNDEERE in reply to buickanddeere, 09-28-2007 08:51:58
THANX ILL CHECK THAT OUT
