3020 Hydraulic problem
Glen Bergland
09-27-2007 20:00:14
I have a 3020 with an after-market 3-point hitch. Recently I unhooked my 3-point tool in order to do some draw-bar work. When I reattached my 3-point tool, the hydraulics won't raise the tool. It doesn't go up or down (maybe about an inch, so it's not completely dead.) The steering and brakes work fine. The system was low on fluid so I added fluid to bring it back to the full mark. Anybody have any ideas on what might be the problem? Is it possible for the system to get airlocked? If so, what's the cure? When I was unhooking and re-hooking the 3-point implement I didn't touch the hydraulics. I'm perplexed???
R. John Johnson
09-28-2007 05:53:52
 Re: 3020 Hydraulic problem in reply to Glen Bergland, 09-27-2007 20:00:14
If this is the style of aftermarket 3 point I've seen there are simply a pair of cylinders mounted on the side of the tractor to lift the arms. No load/draft linkage. Cylinders are connected to the remotes on the back of the tractor. Just lift up and lower.
Try the remotes on another cylinder and see if they are working.
John
Tx Jim
09-28-2007 04:03:45
 Re: 3020 Hydraulic problem in reply to Mike M, 09-27-2007 20:00:14
Buickanddeere mayI ask what feedback/lever/linkage for draft control are you refering to? Glen have you tried re-positioning the L/D control lever under seat? If tractor isn't side console model does 3pt control handle/cable move freely? You may need to go in hole in rear-end and adjust L/D linkage. Tx Jim[/quote]
buickanddeere
09-27-2007 21:04:44
Is the feed back arm/lever/linkage for the draft control re-connected and properly adjusted?
