Electric start and lights isnt so much what matters, its whether or not the tractor is an older model that used a 3 brush genny with a Low/High charge combination light switch and a simple 2 wire cutout relay versus a later model that used a full fledged Voltge Regulator and didnt rely on any Low or High charge light switch setting (just had an On/Off light switch only). The low high charge light switches were for use on the older cutout relay and 3 brush genny systems while the simple On/Off light switch only was for the voltage regulator systems. A parts book will have the serial number breaks for which light switch n system was used or Jim at Agri services in New York who sells both kinds of switches can tell you what your tractor originally used. SOOOOOo your tractors serial number,,,,, ,,if it has a cutout relay or a voltage regulator,,,,, ,,will be helpful to whomever you buy the switch from. The older Low/High switches could still be used with a VR to turn lights on or off, its just that you wouldnt use the terminal that wired to the genny i.e lights on or off function only best wishes John T
