3010 syncro-range transmission parts
don day .missis
09-27-2007 11:41:37
open up the trans on the old 3010,major problem,,on the countershaft item # 7,part # R26243,does anyone know where I can fin a cheaper on then from JD 1299.50. also 4th & 7th gear. thanks in advance'
Don Day
[email protected]
TylerARK
09-28-2007 14:54:17
 Re: 3010 syncro-range transmission parts in reply to don day .mississippi, 09-27-2007 11:41:37
Don, I caught the UPS truck coming back through and got the shaft and gear on the way to you. You should get them Monday.
Thanks, Tyler
matthies
09-28-2007 10:34:22
Before you replace that shaft with an original make sure that the rear most gear on the top shaft is good. On the 4010 I did, somebody before me replaced the rear most gear (reverse?) on the topshaft that also requires the replacement of the countershaft and gear on lower shaft and they didn't and then ruined the countershaft and lower gear on mainshaft. So you might want to change it now or you'll be doing this again later. I guess aleast check it out first. chris Hope I made sense of this to you.
TylerARK
09-28-2007 06:08:21
Don, I have those in good shape. Only have one of the R26243 countershafts left.
R26243 shaft- $300
R26990 4th & 7th gear- $75
Plus UPS.
Thanks, Tyler
L&L Parts & Equipment Co
1-800-538-8350
MSM
09-27-2007 13:07:12
Try Martin Tractor in Newville Pa. 717-776-7542,they ship UPS usually within 1 day.
