Flush 4010 cooling system
Iowa Ron
09-27-2007 10:54:39
Whats the best [safest way to flush system ,with out hurting the o-rings???. i once loaned a 4020 that had sitting for years to a neighbor to use on a big augar ,scored a piston torn it down and found green slime around the liners,could not displace the heat want to plow with a 4010 that has set for 5 years what should i do???
MSM
09-27-2007 14:33:54
 Re: Flush 4010 cooling system in reply to Iowa Ron, 09-27-2007 10:54:39
The safest way would be to drain the old coolant,remove the lower hose,remove the petcock on the side of the block and flush out the block several times with a garden hose through the block drain.It should rinse out any old gelled antifreeze and loose rust,and not harm the liner seals.Maybe add some good coolant conditioner (NAPA COOL or Deere's equivalent) along with a good quality antifreeze and soft water. If it has been sitting for a while, change the engine oil and filters and the fuel filters,and hydraulic filter,a little preventative maintenance will go a long way.
