1020 won't start when hot
Colin Brown
09-26-2007 18:34:43
My 1020 (gas) starts right up when it"s cold, but when it"s been working and shut down (like for refueling), it won"t start. It"s as if I"m not even turning the key - there"s no response at all.
I suspect the neutral safety switch, but by the time I remove the transmission cover and test the switch, the continuity is normal. Are those switches affected by heat? I"d hate to replace the switch, only to find out that it wasn"t the problem.
I"ve done some searching for the replacement switch, but come up blank except for the JD dealer. Since they want an arm and a leg for parts, I"d appreciate any other vendors that might have this part. Thanks for any light that you can shed on this.
V J
09-26-2007 19:49:35
 Re: 1020 won't start when hot in reply to Colin Brown, 09-26-2007 18:34:43
This is VERY RISKY but it works . Connect the two wires together at the neutral safety switch BE VERY CAREFUL AS THE TRACTOR WILL START IN GEAR !!!! this will check the switch to see if it is the problem , if this doesn't do it , then i' d check the ignition switch , then the starter and solenoid , A test light works real good for this also before you do any of this check the battery connections both at battery , grounds and solenoid . If it has an amp guage check to see if their is conitunity across the posts ,then the wires from the start switch to safety switch , to starter solenoid . Hope this helps sounds complated but it is real simple to check it
Colin Brown
09-27-2007 18:39:02
 Re: 1020 won't start when hot in reply to V J, 09-26-2007 19:49:35
V J -
Thanks very much for the useful information. I'll be very careful when bypassing the switch - I may be crazy, but I'm not stupidthird party image I guess I should operate without the transmission cover for a while so I can get quick access to the switch and figure out if that's the problem.
Assuming that the neutral safety switch is the culprit, does anybody have a better (which is to say, less expensive) source for replacement parts? Thanks, as always, for all your help.
CB
