CORRECT GP A PARTS
TIMAR
09-26-2007 18:16:32
I recently purchased an early open-fanshaft A with ser. no. that has is below 411,010. I am trying to get the correct parts before starting the restoration. Looking for thin trans. cover with the small dia steering pipe support, rear smooth back without the oil fill plug or a single pedal power lift without the fill plug, correct steering wheel with the big center hub, casting on the governor that the fanshaft goes into, center-fill tank, and starting tank elbow with shut-off on it. Any leads would be apppreciated.
P Browning
09-27-2007 10:15:49
 Re: CORRECT GP A PARTS in reply to TIMAR, 09-26-2007 18:16:32
This note is to TIMAR, anyone attacking their first tractor restoration - - -
TIMAR -- Yours is a case where I found Green Magazine and also Two-Cylinder Magazines a great beginning point. Then go to WalMart or Staples and buy a small Rolodex card file. Take the first issues you receive and begin your file. It takes some time & effort! As new issues come with new vendors, update the file. And you hear news of suppliers here and there, update your file. Often when you call a vendor for something & he tells you he don't have what you need, ask for a referral -- and bingo, you have yet anther file entry. Before you know it, you will have many folks to turn to for the things you need.
You will learn of special folks out there who zero in on a specific model or series -- of men like Bob Lovegrove who is a guru on JD-BN tractors. The possibilities are unlimited. Another source of data is go on the Internet and find out who attends the Gathering of the Green, an event where Who's Who in John Deere tractor restorations gather every two years! Many are suppliers like Marlin Smith, Detwiler & Tom Shephard. Others include masters of specialty like Jerry Trcka (Gauges), Robert Beaver (Carburetors), Travis Jorde (Decals), Duane Larson and John Nordhoff (Magnetos+), and the listing goes on. This gathering is a great bunch and I only wish my health was such that I may dare to join them one year -- unworthy as I am!
As you will find, the magazines are your main connection to those providing both goods and services needed by the "Community" or restorers. This forum is a great place for many questions, but not for all.
And you must practice patience. You've just bought the tractor and surely, there is much to be done that does not involve the parts you are seeking. By being willing to sort of wait and see on some things, the amount paid can often be lower!
A basic MUST DO is to acquire as much documentation as you can on your tractor. Go to the JD-H restoration site (below), and under ARTICLES 1, one-click on the drop-down DEERE PUBS. Page 2 of this piece identifies manuals Deere is still selling for the "letter-series" tractors, and page 1 tells you how to obtain them.
One tip also -- I think that if I were to be attacking an unstyled "A" tractor, I would ALSO purchase the PC675 parts catalog for the styled "A". The main reason is to illustrate how the parts of subassemblies go together. The Deere documentation for unstyled tractors will not have illustrated parts breakdown drawings like the PC675 -- just a thought! And while the tractors did change, many areas like the clutch didn't change that drastically. (PatB)
TIMAR
09-27-2007 10:42:57
 Re: CORRECT GP A PARTS in reply to P Browning, 09-27-2007 10:15:49
I hav e done several of these unstyled already, just need a few hard to find parts. Thanks
Dwayne
09-27-2007 04:41:02
I know that Detweiler makes the trans cover and steering support. K&K might have the fuel tank. if not, you can take a side fill tank and un solder the starting tank and rotate it up, then you would have to move the fill. I think Polk still makes the steering wheel. I was at Denglers a while back and he had a boat ancor single pedal lift. Hope this helps.
George S. in the real N.Y
09-26-2007 23:07:23
Best way to find those parts is to find another early tractor that
has them and buy it. The items you list were replaced inorder to get some use out of the tractor. I know of an A with early trans cover that has cracks in it and has a homemade brace on the steering post, and guess why, 'cause with hard steering it was easy to have the post or cover break. It is ok for parades but will not take the abuse of feild use. Best plan would be to use what you got and enjoy.
ram ranch
09-26-2007 20:13:45
good luck on finding all those parts, they don't grow on trees nor do's the money to pay for the parts IF you can find them. I've been working on a late 34 A serial 413*** and was lucky enough to have a good center fill fuel tank, and upper water pipe assembly, and brass carb. I have since picked up a 35 A serial 417*** for parts.
