JD 2840 PTO PROBLEM
SHORTORDER
09-26-2007 15:09:46
I'm looking for someone that really knows the 2840 forward and backwards. I have a PTO problem and do not want to separate the tractor. Is there away to check the PTO system out using air. If there is someone out there just let me know and I will get you the whole picture.
Tx Jim
09-27-2007 04:04:09
 Re: JD 2840 PTO PROBLEM in reply to mjbrown, 09-26-2007 15:09:46
Shortorder as MSM stated 2840 and 2940's have long been known for their hyd problems. Have you checked pto clutch & brake pressures? When I worked for a JD dealer I would pull shifter cover on said tractors and blow air in those oil tubes "notorious for cracking" and look for air bubbles in the trans oil. Had a 2840 under warranty that snap-ring popped out of pto clutch and trashed the trans. housing. It took a long time to get trans housing from Germany!!!! Good luck on your repair,Tx Jim
MSM
09-26-2007 16:34:32
 Re: JD 2840 PTO PROBLEM in reply to SHORTORDER, 09-26-2007 15:09:46
The 2840 and 2940 are noted for hydraulic problems.Most of the pto problems on those tractors are related to cracked,disconnected,or out of place lines going to the pto valve and clutch pack, or coming from the charge pump.Some can be repaired by removing the trans top,others may require a split depending on where they are routed.Another source of problems are the sealing rings on the clutch pack itself.
SHORTORDER
09-27-2007 04:02:07
 Re: JD 2840 PTO PROBLEM in reply to MSM, 09-26-2007 16:34:32
MSM Sounds like you have been there before. I checked the PTO Clutch operating pressure and it is not within specified range. Now the question, is there away to pin point the problem before seprating the tractor. Like removing the gear shift cover and force air into the different pipes and local the problem or removing the control valve assembly and force air into those pipes. My problem is that the PTO is working fine but problems with the front end loader. I have a front end loader on the tractor and when using the PTO it will bleed down. When I try to raise the bucket, with the PTO engaged it will not raise the bucket. I stop the tractor and disengage the PTO and their is no problem with the bucket. I had the tractor seprated to repair the Multiple-Disk Clutch. So it is possible a cut o-ring somewhere in the system. I would just like to isolate the problem before seprating the tractor. If possible maybe you could give me your phone number so that we might be able to discuss this over the phone, it is hard to put everthing in a message on the computer. That is if you do not mind doing that. My email address is [email protected], if you send your phone number and a time I could call you, that way the whole world does not see it.
shortorder
