Governor Problems
Larry2809c
09-26-2007 13:49:06
I have a 1947 John Deere Model B that I purchase and I dont think the linkage is correct between the carb and the governor and the throttle and the governor. If anyone has a 47 model B, would you take the time to measure the length of the rod from the throttle to the gov, and also the length from the gov to the carb. This may solve my governor problem because I think it is not adjusted properly. Thanks
Mike M
09-26-2007 14:27:05
 Re: Governor Problems in reply to Larry2809c, 09-26-2007 13:49:06
Unhook the one from the gov. arm to the carb. Push the throttle lever wide open so it pulls the gov. arm as far as it can go. Now hold the carb. throttle lever wide open. Your gov. to carb. rod should be long enough to adjust it so it is 1/2 of a hole SHORT of going in. You can then just pull it against spring tension to hook it up. The other one needs to be able to close the throttle all the way off when pulled back and open up far enough when pushed forward to reach fast idle speed setting.
