Few weeks back a friend wanted to experiment with different fuels in his G and so asked me if I'd mind hooking it to my dyno. It's been modified some but outside of the chrome stack it looks just like what left Waterloo though you wouldn't want to put distillate or K1 in it! I think he has a 70 cam in it or maybe just a G reground? Not sure but it's not an original cam. Anyway I said.... No problem! Had Gasoline in the big tank & pure E85 in the starting tank. Running great on the gasoline, fully warmed up, he twisted his load needle around to make sure we were at peak HP output. Then he switched it to the E85. Ran fine there too but the peak HP quickly rolled off about 12 HP as I recall. (I really should start to keep a good data history but that's 'nother day). I asked him if he'd opened up the load needle any. He said yes. How much? 'Bout four notches! I laughed and said go grab at least a half turn MORE! We gained about 8 HP. Another quarter turn or so & it was up to the Gasoline HP output. He didn't want to tinker with timing so we left that alone though it may have had some effect if we had. Asked him what does all this tell you? -Burns E85 JUST FINE! -No weaker on E85 than with Gasoline. -Will burn a lot more gallons of E85 than gas to get to the other end of the field with rated a load hooked to the old G's tail! Amen! The one thing that surprised me was how well it ran on the E85 though on a severe lean setting from peak performance setting! It did not miss or even falter burning the E85 with the carb still at the gasoline settings. Try to lean it down 3/4'ths of a turn from peak HP on gas & you'll be starting it again or grabbing some choke! Thought some might find this interesting. I had fun with it! Later.
