Grills 39 JD A
Dave Forbush
09-26-2007 06:53:58
I understand that there is a difference in the grills for this tractor. Does anyone know what that difference is?
Maark
09-26-2007 10:01:41
 Re: Grills 39 JD A in reply to Dave Forbush, 09-26-2007 06:53:58
The only difference in the grills for an A and B tractors was the use of twisted wire used in the grill screen for the early 1939 models.
Dave Forbush
09-26-2007 14:56:23
 Re: Grills 39 JD A in reply to Maark, 09-26-2007 10:01:41
Thanks, Maark!
Dave
CLW
09-26-2007 07:42:01
Dave, the parts book shows that all A's from serial number 477000 (1939) until the end of production used the same grill. AA2238R on the RH side and AA2239R on the LH side.
P Browning
09-26-2007 15:06:33
 Re: Grills 39 JD A in reply to CLW, 09-26-2007 07:42:01
CLR -- The parts book tells us of the latest JD part that will do the job. If the parts book indicates the part is good for all serial numbers of this model, the part cited has the FORM, will FIT, and will indeed FUNCTION in place of the original part. Earlier versions since retired generally WILL NOT be listed unless they have some feature that makes them unusable on a specified range of serials numbers, usually later builds. For one classic example, see (below) an excerpt from the JD-H Restoration Guide as relates to a drawbar change (JD-H) brought about by Deere's decision to comply with ASAE's standardized drawbar/power shaft configuration specifications:
EXCERPT: In accordance with this change, drawbar H1030R was introduced which replaced the then-current H675R. H675R is similar to H1030R in that it had an offset bend that permitted high and low drawbar positions by inverting the drawbar. H675R also featured two pivot pin holes to facilitate drawbar extension or retraction. However, H675R had only one hitch pin hole to attach implements, whereas H1030R has two holes (see figure 607). H1030R retrofits tractors back to S/N H-7186, and thus H675R has disappeared from today�s parts references as a direct result. Deere & Co. saw no reason to retain H675R as a separate part. However, going by serial number applications, it appears the following approximate quantities of drawbars are �out there�: 6,185 of AH508R, 40,418 of H675R, and 13,321 of H1030R. So, the �extinct� H675R drawbar is by far the most frequent drawbar you are likely to see. ++++
We see this same thing with respect to sheet metal fasteners for styled A, B, G & H tractors -- and probably involves some others too -- I have first-hand knowledge of the ones cited. In many cases, the call-out is described as a hex-head cap screw, plain & simple. The fact is -- such a fastener was NEVER used in sheet metal bolts sets on these tractors. The latest configuration for A, B & G tractors was hex-headed sure enough, but with a clutch drive! Big Difference!
The parts catalogs are a great tool, but do not use them as evidence for historical change. They tell a story of parts that will do the job, and not necessarily of which version was installed at the factory. This post illustrates the difficulty for those trying to restore a tractor to its "as-built" configuration. The early years of most models prove quite interesting in this regard -- mainly as a result of finding that "just-right" vendor for parts made outside the Deere factory -- wheels being a most common class of parts. One's research reaches into many areas of information flow. (PatB)
Dave Forbush
09-26-2007 14:58:06
Thanks, CLW.
Dave
