1937 B running on one cylinder
MTC in WI
09-25-2007 16:30:44
Hi guys-have good fire at plugs and good compression but will not run on one cylinder.Gas must not be getting to cylinder.Any ideas to check out?Thanks Mike
1936
09-26-2007 06:41:51
 Re: 1937 B running on one cylinder in reply to MTC in WI, 09-25-2007 16:30:44
Had the same problem and replaced the wires with solid wire and problem went away.
JDNPC
09-26-2007 03:22:39
i would check to see if the plug is cracked or jumping the spark to the block. i bet if you look close in the barn or garage with the lights dimmed, you could probably see where it is jumping or atleast you could eliminate that theory off the list. sound like a plug issue.
teddy52food
09-25-2007 18:03:08
Short out the one you think is firing. If it still runs it is firing on both. If not, switch plugs & try again. If the miss changes ,one plug is bad. You may have a hole in the manifold between ex & in on one cylinder.
Mike M
09-25-2007 17:40:03
Are you working it or just idleing around ???
If not working sometimes the RH. side doesn't really fire alot.
Youe plug fire maynot be as good as it looks as it can break down under compression. Plugs NEW ? wires have wire in them ? cap not carbon tracked ?
