Adding Hydraulics
David Buchwald
09-25-2007 12:34:06
I have a JD 4020 (old serial number) and I have a loader on the front using both hydraulic ports on the back. I've purhcased a grader blade, but don't have any more ports to plug the hydraulics into. How can I add additional hydraulic ports (and controls) so I can run both the loader and blade at the same time? Is there a kit to add an additional pump, lines and controls for the blade? If so, where can I find instructions.
Gerald J.
09-25-2007 15:17:26
 Re: Adding Hydraulics in reply to David Buchwald, 09-25-2007 12:34:06
third party image
There's an elbow near the brake pedals. Feeds the 3 point valve out back. Change that to a T. Gives you full system pressure and flow. You need the loader valve to be closed center, return to the transmission oil filter cover (look for a cover for a 2640 with the tapping or drill and tap the one you have). On my 4020 I have two circuits tapped, one for loader and one for a back hoe. I also have a flow restriction valve for each since both loader and back hoe need only 5 gpm, its too hard to control them with 20 gpm, they move too fast.
The hoses are standard, take the elbow with you to Deere to find the T that fits. The loader valve HAS to be set for closed center and many have that option. Don't need a kit, just some parts.
Gerald J.
MSM
09-25-2007 13:20:24
You can add an electric/hydraulic splitter off of one of the remotes. Or pick up a loader control valve,and plumb it directly into the tractor,leaving the remotes free.
