JD #5 mower (update)
Mike C Mn
09-24-2007 18:09:25
I picked up the mower yesterday,boy is it in nice condition. Very complete,all the guards, shoes,etc. are there. Only things i need to find are,the guard for the shaft, and the lifting handle. It came with a hyd. cylinder, but my tractor has no hyd. Also came with the foot pedel for lift, but no way to lock it in the up position with out gettig off the tractor and attaching a rod. How can you hold down the foot pedel and hook up the rod with out the bar falling back down? It also appears i"m going to have to make some modifications to my draw bar in order to hook up the quick - tatch hitch. Also got a freshly sharpend extra knife. Anybody have some advise on how to modify that draw bar on the 44 B to connect this hitch? Well, Thanks again for the info. you guys supplied before i drove 100 miles to look at this baby.
Mike C
James Howell
09-25-2007 12:11:40
 Re: JD #5 mower (update) in reply to Mike C Mn, 09-24-2007 18:09:25
third party image
First of all congratulations on buying your #5 caster wheel power mower!
I agree with sgtbull, you need the lever to lock it in place. His price on the lifting lever is also very good.
The guard for the shaft ( telescoping shields over the power line ) consist of a front and rear shield.
You can contact David Kratzer at [email protected] and discuss your needs.
He sold me a guard and he also sold a guard on eBay a few weeks ago. If anyone can get you a guard, he can.
He has always been quick to respond and usually provides photos of the part(s) being offered.
You are very fortunate that your mower has a foot pedal ( foot lever ). I have seen only five foot levers: one sold on eBay about a year ago for $65, two in photographs, one at a local tractor show in June, and the one on my 43B.
You are correct; the foot lever is not designed to lock in the up position. You must get off the tractor to attach the latch rod to the cutter bar.
Before you attach the latch rod to the cutter bar, put a 2x4 pine wedge/block between the knife and a knife guard secured by a small bungy before raising the cutter bar. As I found out the hard way, the knife will �bottom out� on the cutter bar and the cutter bar will not lower.
It is VERY IMPORTANT to raise the cutter bar with open hands using your palms. DO NOT under any circumstances put your hands or fingers inside the knife guards between the knife sections. Otherwise your wife, girlfriend, or significant other will be typing all your future posts on this forum.
Once you have the latch rod and cutter bar attached, then push the lever forward towards the tractor to lock it in place.
Pat Browning has once again given excellent advice: go to the JD No. 5 Mower Site for some great graphics and other information on this mower.
The mower mounts/brackets that are illustrated are sometimes available on eBay. There are two pair on eBay at this time Item number: 170151473581 and Item number: 130154651087.
My advice is to buy one of the above items and bolt them to the drawbar on your 44B.
You will love the combination of your 44B and #5 sickle mower; in one word �SWEET�.
Hope this helps.
P Browning
09-24-2007 20:25:00
For some great graphics on this mower, go to the JD No. 5 Mower Site (below). (PatB)
sgtbull
09-24-2007 19:38:49
guess it would help if I included my email, eh?
sgtbull
09-24-2007 19:29:36
You need the lifting handle to lock it in place. I've got a spare.. if you want it, how about $10 and shipping?
