Here is an excerpt from the JD-H Restoration Guide that may give you some pointers -- (PatB) RUST CONVERSION -- This step is a treatment to halt red rust. Use a compound containing phosphoric acid, which will convert remaining red rust into iron phosphate, an inert oxide that turns the metal black. One such product is OSPHO, also found in the paint section of hardware and home improvement stores. Add OSPHO to the tank. Close and move tank about to ensure all surfaces are contacted by the solution. Open the tank to dump solution out and allow air in. Allow open tank to stand for a period of time up to 15 minutes. Inspect for red rust. If found, add OSPHO back into tank a second time, and so on until no red rust is found. When satisfied that all red rust has been converted to iron phosphate (its black), rinse repeatedly with water until the out-flowing rinse water is clear. STRUCTURAL REPAIR -- Before repairing the tanks, it is essential they be cleaned and rust-converted as above. If you have any solder joint leaks, the tank has been deodorized to the point that it can be safely re-soldered with flame. To repair rust-throughs, JB Weld applied on the tank's exterior regions comes in handy for this. Once you have removed all the exterior rust you can reach, flush the remaining rusted areas with OSPHO�, and after it is cured, wire-brush clean before applying JB Weld. LINING A FUEL TANK -- If you've determined the tank must be sealed it with a liner, a thoroughly cleaned, rust-converted and structurally repaired tank are the preparation steps. Part of the tank lining process will be an etch phase followed by a drying phase to prepare the tank surface for the lining compound. There are three popular compounds used for tank liners. They are (in alphabetical order) KREEM, POR-15, and RED KOTE. The choice of which one to use is left to the reader. Many times, a choice is made on which of these products is (are) found readily available. For a typical John Deere Model H Tank assembly, one quart of sealer should be sufficient. Search for product reviews on such products prior to making your selection.
