3020 ps
TWOPOP
01-25-2000 18:27:59
as i think i said earlier,the main reason for creeping is that there are clutch discs that are warped. when you test the 3020 next time,push in the inching pedal and shift thru the gears slowly,do this on level ground. see if the tractor creeps,in any gear. as you jd man stated the problem is probably in the front clutch pack.another problem with the powershift tractor is that the remote hyd couplers need to be kept in good shape because,if they leak internally they will add a lot of heat to the trans oil which can cause seals in the clutch packs to go bad and also help to warp discs
