They are breakable, but you have to work at it. You have to work really hard to break one. I'm running 11.00-16's on the front of my 4020 to keep the front end from sinking into the ground when the loader is loaded. I think that preserves spindles too. Originally the 4020 diesel came with a split 24 volt system that works, though the generator is only 10 amps so it can take hours to charge the batteries back up after a hard start. Those without side console (3 point on the dash) do loose the push-pull cable for the 3 point. It rusts fast. It is practical to tap the hydraulics directly for loader or added remotes though how its down depends on the vintage, side console is the later version. The side console tractor started with SN 201,000 is enough different from the previous version that the parts books and shop manuals are completely different books for the two tractor versions. And there were sometimes cconstant changes on details during the 9 years of production. Today a 4020 which can be 44 years old won't neceessarily be absolutely trouble free, but its as fixable as it ever was with parts available all over and its easier to fix than the late model computerized tractors. Like others have noted, the Power Shift transmission is tough, and hard but not impossible to break or wear out. But if it doesn its very expensive to fix. Gerald J.
