Looking at JDPARTS, it does appear that tractor used an "automotive-type" fuel lift pump, as well as a DB-series Roosa-Master injection pump. Start with the lift pump on the RH side of the engine... if the diaphragm goes bad, the leaked diesel is supposed to drip externally, through a "weep hole", but it doesn't always work that way. If the left pump is OK, likely the shaft seals in the IP have failed. You REALLY need to have a shop manual at hand, if you are intending to remove the IP yourself. The engine timing marks need to be aligned, and the pump drive gear has to be removed with a puller. Once it's removed, it's a fairly simple matter for someone who's done it before to replace the shaft seals. SOMETIMES, the bushing in there wears and needs to be replaced. NOT a job for an amature. Take it to a diesel shop, and they'll go through the whole pump, and "freshen it up" with new seals, perhaps a governor update, new transfer pump vanes, and some other odds and ends, and run it on the test stand, you're easily looking at a bill there of $300 to $600.
