5203 Pivot Pin, how do I grease?
Boone
09-24-2007 06:41:12
How does one grease the pivot pin on a 5203. I don't see a grease fitting. Do I need to pull it?
Thanks!
leon
09-25-2007 03:36:46
 Re: 5203 Pivot Pin, how do I grease? in reply to Boone, 09-24-2007 06:41:12
Can't believe it! Out of curiosity I checked the JD parts web site. there are two axle versions shown and neither shows a grease fitting for the axle oscillation pin. Just bushings and seals. Makes one hope that they are good seals and they probably are for they are likely the same ones as are used in the versions of the tractors that go into rice paddys and work under water.
RobMD
09-24-2007 15:12:19
don't your operator's manual tell you?
Boone
09-25-2007 04:38:37
 Re: 5203 Pivot Pin, how do I grease? in reply to RobMD, 09-24-2007 15:12:19
The manual just states to grease it and doesn't give the specific on how too? I'm not overly impressed with the JD owners manual and some of the how too's.
Mike M
09-25-2007 05:37:44
 Re: 5203 Pivot Pin, how do I grease? in reply to Boone, 09-25-2007 04:38:37
Their "newer" equipment and even books leaves alot to be desired.
