70D flywheel (learn from my stupidity)
WeirdDeere
09-23-2007 22:42:04
Check your flywheels!
Ya'all can slap me for being stupid. I sure feel like it. I hate to even admit this. This is very much a whiny message. Sorry.
Short version:
The flywheel is loose on my 70D, I haven't taken it off, but the crank is most likely trashed too. It's VERY loose (radial movement).
Long version, so maybe others will learn:
The 70 has had a knock for a while. I've owned it for two years...when I first started noticing something amiss, I thought it was the clutch rattling (the plates had ovaled holes). The knocking changed/lessened when I disengaged the clutch (lever forward)
I DID look at the flywheel too (about a year ago). It didn't seem to have ANY radial movement. I didn't touch the flywheel bolts. I figured to let sleeping dogs lie-it was an original type flywheel that had stayed tight for fifty years-why would it loosen now? I barely run the thing, much less WORK it.
Endplay was a bit much but I thought that was from worn 70D style internal thrust washers, and I would get to that project THIS winter. I was gonna replace the ring gear and work on the clutch too. But I didn't do it immediately, because I wanted to enjoy it for a while, I get tired of EVERYTHING being a project.
So...I ran it. I know now that the knock was getting worse, but I just didn't realize it (I became accustomed to it I guess). Thought it was a combo of diesel knock and clutch rattle (it definitely sounded louder on the right side of the tractor).
I didn't realize how bad it was until I compared it to some 70D-720D-730Ds at our local show. But I was still optimistic. I had looked at the flywheel earlier! It was just a combination of everything, right?
Wrong.
Took the flywheel cover off on Sunday and made my discovery of the very loose flywheel. Peachy. Just peachy. I don't know exactly what I'm gonna do at the moment. I can't and won't drive it any longer, but I don't want to rip it apart...too many projects already. Nothing runs around here anymore. The 80 transmission is spread all over. The Case VAC blew a rear tire. The IHC W-30 won't hold water. The D won't run right. The B does run, but doesn't want to charge now. And now the 70 is down for the count. I don't even know if a Taper-Lock will work. I hate to spend, what, $1000 to find out that it won't work? Not to mention all the other issues with T-Ls. Getting endplay set (I dunno about 70Ds though), rubbing on the flywheel cover, etc.
The worst part about this. I probably could have caught it and fixed it with new bolts a year ago. I could have paid attention to the advice I've seen at YTmag and Johnnypopper.com. But no. I figured I was lucky...it wouldn't happen to me. It seemed tight, right? With my track record, I should have known better than to think I have any type of good luck.
My new saying,
Murphy's Law? Ha! He was an optimist...
Murphy never met me!
Brandon
two cylinders saves gas
09-24-2007 16:55:04
 Re: 70D flywheel (learn from my stupidity) in reply to WeirdDeere, 09-23-2007 22:42:04
Sounds like you got alot of work in the barn. I'm not a mayjor collector or anything or expert. I dont know how some of you guys do it with so many tractors to work on and maintain. I'm fond of my 2 deeres and im stopping there. Just keeping two in show condition is enough work for me. Youll have to let me know if you get that d running good or not brandon.
09-24-2007 18:11:38
 Re: 70D flywheel (learn from my stupidity) in reply to two cylinders saves gas, 09-24-2007 16:55:04
I beleive thanks to Mike M awile back my flywheel install went ok . For everyone should check there horizontal two cylinder flywheel for looseness, and install new grade 8 bolts on taper lock flywheels.
buckeye al
09-24-2007 14:30:53
BTDT. Tore that clutch side down to the main case twice looking for the cause of that slight sporadic pounding nosie. I checked the flywheel bolts. No problem there. Goot-n-tight according to the torque wrench. I did not know the loose flywheel nature of these buggers until a couple months later. That caused me to check the flywheel over with a fine toothed comb. Sure enough, it was hammering the splines out of the flywheel. I was very fortunate and found my trouble early. Could just see some cast iron dust forming under the pressed steel lock nut when it was removed. Took the flywheel off & found one of the bosses had cracked parallel to the bolt on the back side.
I was lucky (or ignorant, it's a fine line some times) enough by virtue of having tightened my flywheel bolts that there was no visible damage to the crank. If one tried hard maybe they could find a few thousandths here or there but anyway, my taperlock was installed in about '83 or '84 I'm guessing. Went on just fine and has performed almost flawlessly. I had it walk out & have shaft end play grow so I had to re-position it.
I don't regret buying the taper lock at all becasue it saved my 70D. Tractor is still going strong.
Good luck.
RobMD
09-24-2007 10:41:02
Ever see 70's and 720's with their flywheel covers off all the time? I've seen a few and farmers say that's vital when they work their tractors that they check their flywheel every so often and re-torque all the time.
buickanddeere
09-25-2007 10:12:19
 Re: 70D flywheel (learn from my stupidity) in reply to RobMD, 09-24-2007 10:41:02
If the fasteners & splines are good. Multiple re-torques are not required.
mjbrown
09-24-2007 05:29:31
I had the flywheel strip on my 730D while raking hay. It stripped off all the splines in the flywheel. The splines on the crank were not that badly munged up. I fixed it with a taperlock from Allen Machine Works. They have to be installed exactly as they tell you or they too can come loose.
Bottom line is, your misery has lots of company and it isn't the worst repair in the world.
Mike M
09-24-2007 05:14:45
I'd say a taper-loc installed properly and rechecked for tightness after a while will work fine.
I once bought a 720D that had the fylwheel come clear off while running. At least that's the story I got ? I was able to still get a good used one to tighten up on it. Go figure ?
