720 steering
Ron Muhlenkamp
09-23-2007 17:36:24
My 720 with power steering doesn't want to turn right about 20% of the time. Usually jogging it back and forth several times will free it. Other times it works fine Have replaced the fluid. the old fluid looked good. Suggestions?
Ron
Bob
09-24-2007 09:16:40
 Re: 720 steering in reply to Ron Muhlenkamp, 09-23-2007 17:36:24
Besides all the possibilities for problems in the VALVE area, the bolts holding the "vane arm" to the steering shaft inside the "steering motor" down low in the front bolster commonly break, causing the vane motor to jam. And, probably making a gouged-up mess of it, as well.
lonzo
09-23-2007 18:46:12
I suggest you get a manual and start from there ,I could tell you a few things but you might not understand until you went threw the manual. It sure wood make it easer for everybody. I hope i can help,
Ron Muhlenkamp
09-24-2007 07:16:19
 Re: 720 steering in reply to lonzo, 09-23-2007 18:46:12
I have a manual, I"m trying to figure out why it works sometimes and not others. I thought maybe some dirt was floating around. Judging by the amount of adjustment required to balance left to right, which I"ve done, some of the clearances must be pretty small. But the fluid is clean.
Ron
Mike M
09-24-2007 16:27:26
 Re: 720 steering in reply to Ron Muhlenkamp, 09-24-2007 07:16:19
Look very close at the worm gear and it's adjustments. There is also 2 different styles. If you have the later "improved" design there is a real good chance the edges of the slots the pins ride in are broke off. Someone posted a very clear pic. of one of these not too long ago.
