John Deere 4630 steering problem
BMAN
09-23-2007 06:27:31
4630 steering wonders all over the road. I have replaced tie rods and its getting a rebuilt hydraulic pump. Mechanic mentions metering valve and steering pump could be the problem. Anyone else have any ideas?
shoes
09-24-2007 21:41:29
 Re: John Deere 4630 steering problem in reply to BMAN, 09-23-2007 06:27:31
If it's the old style steering valve. (Like the 10 or 20 series, I have found that if the system is not bled properly, you will notice that the steering is erratic, especially going down the road. If the steering system has recently been apart, this could be your problem. The only other reason for having to bleed the system is if there is a considerable leak somewhere, which should be visible.
lonzo
09-24-2007 01:12:13
Jack up the front end and see if there is any free movement in the spindles, there should be some, the spindles could be stiff causeing problems or tow in and tow out can do the same thing, and yes the old style steering valve will give you fits.
msb
09-23-2007 19:20:59
Serial number?
BMAN
09-23-2007 19:26:49
 Re: John Deere 4630 steering problem in reply to msb, 09-23-2007 19:20:59
Its a 1974 and I think the serial number is around 9,000
