2840 Hydraulic Trouble
Bob 666 A
09-23-2007 02:17:30
Using a ditch bank mower on our 2840 with a single action cylinder. It constantly raises, have to hold the lever forward to keep it at the height to mow. When the lever is pushed to "Float" position in a short time the steering acts like it looses pressure. Right brake works fine left pedal is tight with no brake action. 3 point hitch works fine and the high - low shifts fine. Anyone have any ideas on our problem? Thanks.
Tx Jim
09-23-2007 03:12:50
 Re: 2840 Hydraulic Trouble in reply to wilamayb, 09-23-2007 02:17:30
If you are operating the cylinder using the factory SCV(selective control valve) then a pressure valve inside the SCV is leaking. The SCV needs repaired by a qualified tech. LH brake may need bleeding. Tx Jim
