2510 load control yoke front pin
Scott in SC
09-22-2007 18:11:38
I�m replacing the load control seals, bushings, and shaft on my 2510. I would like to replace the front bushing on the front support (also called support and yoke), but cannot figure out how to remove the front pin. The parts book shows a � x 5/8 �spring pin� that looks like it holds the front dowel pin in place, but all I see is a 1/8 inch hole in an area of the yoke that is perpendicular to the front yoke pin. I don�t see any cross or set screw/pin to remove, and can feel noting but what I believe is the front support pin at the bottom of the 1/8th inch diameter hole.
The JD 2500 series service manual just says to �remove the pin securing the front support to the transmission case�; obviously easier said than done.
Anyone ever remove that pin to remove the yoke or replace the bushings?
I know I may be able to get by without replacing the front bushing, but I already have it, and would like to square it away while I�m doing the seals.
Any help you could give me would be greatly appreciated!
Thanks,
Scott in SC
msb
09-22-2007 20:19:12
 Re: 2510 load control yoke front pin in reply to Scott in SC, 09-22-2007 18:11:38
You got a bear by the tail.No easy task. Do you have some roll pin punches? Drive the roll pin in even with the cross pin and then drive the cross pin out. Then drive the roll pin out of the cross pin after removing it from the yoke. I never knew of anyone besides myself that went to the trouble of replacing the bushing, but I would almost bet the bushing has a groove worn in it where the pin normally sets.Its one of the main reason the load control seals don't last very long after being replaced.Replacing the bushing also goes a long way to restore the original sensing action of the 3 point hitch.
msb
09-22-2007 20:29:34
 Re: 2510 load control yoke front pin in reply to msb, 09-22-2007 20:19:12
Disregard my post about the roll pin. I was thinking of something else. Old timers kicking in, I suppose.
1JDA
09-22-2007 20:09:58
Scott, the pin has a press fit in the two ears of the transmission case. The small spring pin that you mentioned indexes the bushing. The inside diameter of the bushing is not round and has to be positioned to allow for the yoke to move for and aft. I use a big punch (about the size of the pin) and a heavy hammer (BFH) and drive the pin out. They usually come out pretty easy. Good luck.
