110 garden tractor kholer engine
tn.jed
09-22-2007 09:10:58
hi all, was wounderin if ya could help me out i'm putin a new head on my little mower and noticed that on the compression stroke the exhaust valve opens just a little bit is this normal for these small engines its the 8Hp cast iron kholer the valve closes at top dead center just opens maybe a 116" on the way up to tdc
GeorgiaHayFarmer
09-22-2007 09:34:21
 Re: 110 garden tractor kholer engine in reply to tn.jed, 09-22-2007 09:10:58
tn.jed,
Your engine is doing what it was designed for. What you see is an ACR (Automatic Compression Release). It helps with startup as a decompression for the engine and takes the strain off of your starter-generator. The ACR is located on the camshaft and has a foot that raises at start rpm under the exhaust valve lifter.
Scott
tn.jed
09-22-2007 11:00:45
 Re: 110 garden tractor kholer engine in reply to GeorgiaHayFarmer, 09-22-2007 09:34:21
thanks for the reply GHF now I can put on the head and work the little guy
