37 john deere B
MTC
09-21-2007 18:32:33
Hey guys- just restoring a 1937 John Deere B that had a stuck engine.Took head and block off and got pistons out.Very little top ridge in block top.Honed cylinder walls and put in new right rings.Have not had it started yet but seems like little compression.Does it have to run to seat rings?Every thing seemed good and tight.Thanks
Maark
09-22-2007 15:46:39
 Re: 37 john deere B in reply to MTC, 09-21-2007 18:32:33
Unstyled B's didn't have alot of compression. what you are feeling is probably normal. It should get better after it has run awhile..
JDNPC
09-22-2007 05:56:20
i'm doin a 36 & 37 right now, you need to check the top end of the valvetrain, and also check your rings are installed properly. if your rings are new, check to see they were installed the correct way, and then go to the valvetrain and cam position.
teddy52food
09-21-2007 18:38:18
Did you grind the valves and seats?
