1945 H
Wil O
09-21-2007 08:22:25
I have a 1945 H and had to replace the countershaft/gear cluster (that is low intermediate and high gear)the gear cluster I have is keyed on with a 7/16th inch key. The cluster I received from the salvage yard has no key but instead has inside "teeth" that secure it to the shaft (no key!). I dont see this arrangement listed in my parts catalog, they only show the key type. Both gears have the same number of teeth and same dimension...what have I got and should I use it!? Why the difference?
P Browning
09-21-2007 12:41:29
 Re: 1945 H in reply to Wil O, 09-21-2007 08:22:25
Will -- The entire countershaft gear cluster was changed to the use of the H1044R key for 47796-up from all earlier models. This key WAS NOT used before 47796! The good news, however, is that there are no corresponding changes reflected in either the sliding gear shaft and its make-up, and no changes in the main case nor the main (final) drive gear which is attached to the differential. This means that the countershaft gears assembly changes for 47796 & above are entirely contained to the cluster of the three gears and the pinion they mount up to.
The bottom line -- yes, you can successfully use the cluster you received, but you must use it as a unit. You cannot take good gears from you old one and intermix them with some on the replacement cluster -- neither gears nor pinion are individually interchangeable. So if all the gears are okay, you are good to go. BTW, if you have trouble finding new JD7915 roller bearings, get back to me -- I may still be able to point you to a source!
This thread attests to the importance of paying attention to serial numbers when seeking replacement parts. One thing to learn about past practices by Deere & Co. is that when something needed to be changed, they pressed the new change into use at the earliest possible point, and the point of effectivity was more often than not at some mid-point of a production year. (PatB)
Wil O
09-28-2007 17:05:04
 Re: 1945 H in reply to P Browning, 09-21-2007 12:41:29
Pat,
We got the roller bearing from Russ at heartland. Thanks he was a big help. By the way, curious minds want to know, why did Deere change counter shaft gear cluster from one style to another? Have you ever run across any reasons?Strength? Cheaper manufacturing cost? Just wondering...Thanks again
Wil O
09-21-2007 14:07:32
Ok, thanks.
And Yes, we are having trouble finding the roller bearings, can you help point us in the right direction?
P Browning
09-21-2007 15:28:56
 Re: 1945 H in reply to Wil O, 09-21-2007 14:07:32
Will -- I bought two pairs (minimum buy) from an outfit called Applied Indusrial Technologies in San Antonio -- by providing micro-measurements! I can back-track on that purchase if necessary.
But I also am lead to believe that Russ Schworer has them too. He is over at Heartland Tractor Co. (AKA Paul's Rod & Bearing) in Parkville (suberb of KC) Missouri, and the number there is(816) 587-4747.
Now, if you need some help with the San Antonio buy, get back to me via the JD-H website (below) and I will take it from there. On the other hand, if I do not hear a call for help, I will assume you were able to get them from Russ!
--- Before I close --- I wanted to point out a paragraph from the Restoration Guide Update pages that will be important to you. Here it is. (PatB)
Page 86, INSTALLING COUNTERSHAFT ASSEMBLY:
Examine the shaft. Note a holding notch cut into one end. It is the opposite end that is first inserted into the main case during build-up. I found that increasing the amount of chamfer on this "first end" will make insertion easier and reduce chances of possible damage to the JD7915 roller bearing cages. ++++
Wil O
09-21-2007 17:25:03
 Re: 1945 H in reply to P Browning, 09-21-2007 15:28:56
thanks! I will let you know how we make out.
