430 Power Steering
OhioTractorGuy
09-20-2007 19:19:51
Looking for some advice on the later style 430 power steering. . . I have a tractor with the later style pump; everything seems to be there but there is a leak at the control valve on the steering shaft. I have a 440 tractor service manual on the way to guide me thru the rebuilding process. I dont think I should have any trouble locating replacement O rings. Questions I have are what exactly wears out on the inside of the pump? Ive been able to locate a few NOS AT11821 Service Kits with the ring, rotor, and vanes so I picked one up "just in case" (Ive heard of how hard it is to find parts for these). I plan on checking to see if the pump puts out good pressure and if I does I will probably not mess with it. Is it common to see a lot of wear on the shaft and pressure plate (that I was not able to locate)? The only thing Id like to find for sure at this point is a replacement pulley as the one on the tractor now has a crack around the hub. . . I can probably repair it but if I can find another of course Id like to replace it. Thanks for any thoughts/advice.
machinery-man
09-21-2007 06:37:23
 Re: 430 Power Steering in reply to OhioTractorGuy, 09-20-2007 19:19:51
The meat of any hydraulic pump lies in the proper clearances, between gear, between housings, so if you have all that up to specs, then you go to the seals, control valve(wear items involved). Lack of pump pressure is deteriation on wear surfaces. Most of the older tractors were just used till used up, very little detail about changing fluids. I would surmise a lot of them never had fluids changed, maybe added when used...I"m surprised that the any of the old machines are around....I bet there want be many of the current machines in operation without maintenance.
Dave H
09-20-2007 20:08:55
I thought the kits were made of unobtanium>
Would you mind giving your source for the pump kits?
I am still haveing a challenge with the leak on the front of the Char Lynn control valve. I have sdone some searching in vane for rebuilt control valves. Mine leaked out the front seal. I was able to slow it down to almost nothing by working a jiffy sleeve on the shaft and installing an o Ring tha fit tight. But I am frustrated with this litte problem.
good luck
OhioTractorGuy
09-21-2007 05:21:17
 Re: 430 Power Steering in reply to Dave H, 09-20-2007 20:08:55
Hello Dave,
I was able to find the kits at an auction from a dealership that had closed its doors. . . had to pay $100 but thought it would be worth it now vs. pulling my hair out later. Someone else must have known what it was besides me!! Thanks for your advice on the control valve. . . mine seems to have a leak from the front also so Im sure Ill have to deal with the troubles youve had.
