2010 head gasket replacement
Dave / Believer
09-20-2007 16:57:12
I have a 1964 2010 gas with (I hope) a blown head gasket or intake manifold gasket. My question is can I replace the gasket between the cylinder deck and the block without pulling the deck all the way out? I would like to work the gasket into position without sliding the piston rings out of the bottom of the cylinder bores if possible.
I am assuming I will need cylinder head gasket, deck gasket, valve cover gasket - anything else I am missing?
Thanks -- Dave / Believer45
jdemaris
09-20-2007 17:53:40
 Re: 2010 head gasket replacement in reply to Dave / Believer45, 09-20-2007 16:57:12
The 1010/2010 series are the only Deere wet-sleeved engines that never got updated to mulitple seal rings between the engine oil and coolant (not counting pony-motors). So, all your engine has is one single seal ring on each cylinder-sleeve which is barely adequate. You're asking for trouble if you're going through the work of pulling the head and deck gasket - and not renewing the sleeve seals. It's usually what does those engines in. Coolant leaks into the oil and collects at the bottom of the oil pan. Then, one morning you start it - coolant gets sucked up and pushed into the main-bearings - and the engine siezes. In regard to replacing the deck gasket - no - you can't change it without removing the sleeve deck. Last one I had to do - I pulled the head and sleeve deck. I found the top piston-ring grooves very worn which is common on 1010 and 2010 gassers. I recut the top grooves and installed Hastings repair shims along with new rings. Put in a new deck and head gasket, new sleeve o-rings, and was all set.
Tom in Mo.
09-20-2007 18:18:58
 Re: 2010 head gasket replacement in reply to jdemaris, 09-20-2007 17:53:40
I agree! No sense going this far without renewing the O-rings on the bottom of the sleeves.
