J D #5 Mower
Mike C Mn
09-20-2007 16:43:49
I'm going to look at a #5 mower on Saturday. Are their any areas that need a closer inspection for wear? I've never used one of these before,so i need help. I'm going to use this with my 44 Model B to mow about 3-1/2 ac.two or three times a year. Also he's asking $200 for it with a extra sickle,and the original operators manual.Is this a fair price as he says it's in good condition? Any replys will be very helpful. Thanks Guys! Mike C
sgtbull
09-23-2007 00:26:59
 Re: J D #5 Mower in reply to Mike C Mn, 09-20-2007 16:43:49
I've got about a dozen for parts if you need something... and I'm cheap. (my wife says i'm easy too, but that's another topic!)
Soldier Tom
09-22-2007 18:10:03
So did you get it? I have two at home that have been used for many many years. One is pretty beat up, but it still runs along like a new one when the blades are sharp. You will have a great machine there, I suspect. Is it a hydrolic lift set up or what? I have used hydro, and also the cable lift, MUCH prefer the hydro set up. Let us know how you like it.
Walk in peace
Mike C Mn
09-21-2007 04:56:47
Thanks for the info., I'll give it a look this weekend!
Mike C
JOHN DEERE 70
09-21-2007 04:25:30
check the gear box for cracks where it mounts.
Hayfarmer
09-20-2007 18:20:35
The #5 is a good mower, price wise just depends upon condition I think. Check sickle for wear, check guards, if are all in place and have ledger plates, check condition of ledger plates. Look for bent pieces indicating abuse. See if stands are on it, there should be a yoke that pushes down on inside of sickle end and some type of stand on the left side, front. Check type mounts. If it has the quick tatch mounts you will need those on the B also. Check PTO shaft for looseness in universal joints and that it is all there. You may have to modify it to fit your B anyway. Check that the outer end is on the bar, if it has a grass board, either wood or metal it is a plus.
