1520 noise
Bill Ross
09-20-2007 14:47:01
I have a 1520 that makes a rattling noise at idle and up to about 1500 rpm. it does not seem to be effected by engaging the pto or shifting high hi lo or by engaging the clutch. I have replaced the clutch. I suspect it is the hi lo unit but not sure. it is quite loud and annoying. any ideas or somethng I could check to find what it is? I would like to repair it during the winter months. It seems to be coming from the tranny area. It makes the noise in or out of gear, moving or sitting still.
Bill Ross
09-21-2007 05:42:36
 Re: 1520 noise in reply to Bill Ross, 09-20-2007 14:47:01
It does have a independent PTO. So you are saying the hi lo unit is not turning with the clutch pushed in? then now I am stumped. The engine and the water pump are fine.
Mike M
09-21-2007 05:35:02
Worth a check. With the engine shut off grab ahold of the fan blade and see if it wiggles sideways to see if the water pump bearings are going out. You should get no movement. I once worked on a 2240 for a fellow and was glad I checked this first ! Hard to believe it made that much noise travel back to where you sit.
K.B.-826
09-20-2007 19:58:49
So it makes noise when the clutch pedal is down? The only things turning inside of that housing when the clutch pedal is down are the PTO drive gears, that is, if it's got live PTO.
