1936 D quit, won't start
dcmadsen
09-20-2007 13:23:43
D was going up the driveway and quit. Thought I ran out of gas and added some, but still wont start. If I dump gas in the cylinders, it will pop a couple times and that"s it. Plugs are dry, fuel does not spray out the petcocks when cranking it over, but carb bowl is full of gas. It"s acting like gas cant make it from carb to cylinders. Any ideas on what to check?
Ken L.
09-21-2007 16:11:09
 Re: 1936 D quit, won't start in reply to dcmadsen, 09-20-2007 13:23:43
My 1927 D did the same thing a couple years ago. Had good spark when I laid the plugs on top of the block to test them but wouldn't fire when I tried starting it. I mess around for hours. Finally, I changed the points and condenser which only had about 30 hours on them and it's been running great since.
John T
09-21-2007 06:19:35
Im not a very good hand on D's but Ill toss out a few things FWIW.
Even if there was insufficient gas flow to the carb (could still well be reason she stopped), if the bowl is full as you claim thats enough for her to at least start until she starves for fuel again.
The fact that she at least pops as you claim when you prime her makes me think theres st least some spark plug firing going on even if it is weak.
What bothers me the most is you claim theres no gas vapor out the petcocks and the plugs are dry SOUNDS LIKE JUST AS YOU SAY SHES NOT SUCKING ANY GAS OUT OF THE CARB !!!!! !!!!! !I guess you have tried more choking????? ????? ? You need to see some gas vapor at the petcocks in order for there to be cylinder gas vapor to ignite when the plugs (if they are) when they fire. Low vacuum like CN mentioned can reduce gas intake and that can be from low compression, try squirting some oil in the cylinders to help the rings seal n see if she sucks gas in better after that?????/ If that help her start then I suspect worn rings/cylinders buttttt tttt that dont explain her dying in the first place which may well be clogged up fuel system in the tank outlet or any sediment bowl or filters (Do the flow test Duane mentioned) or else the carbs needle n seat has a sticking or clogging up problem.
Pull a plug wire to verify a good blue spark on both cylinders (if not fix that first),,,,, ,,,try some oil in cylinders to improve ring seal n see if that helps improve vacuum n compression,,,,, Do Duanes gas flow test to insure gas is at least getting to the carb,,,,, ,,maybe pull start her if necessary then see if she still dies later from gas starvation (gas flow or needle n seat problem),,,,, ,,,try more choke and/or less throttle on start attempts to try n suck more gas in until you get petcock vapor.
let us knowwwww wwwww
John T
CNESLER
09-20-2007 19:15:00
It could be stuck valves or trash under the valve seat keeping the valve from seating
thus loss of vaccum to pull in the fuel
Let us know how it turns out
CNESLER
P Browning
09-21-2007 01:21:37
 Re: 1936 D quit, won't start in reply to CNESLER, 09-20-2007 19:15:00
But on both sides at the same time????? I'd need to think about that for a spell.
Duane Larson
09-20-2007 14:44:39
dcmadsen,
I would open the carb bowl drain, hold a container under it, and let the fuel flow for a full 30 seconds to make sure adequate fuel is getting to the carb. If not, something is blocking the fuel outlet in the tank, or somewhere else.
If that is all ok, I would check for spark by pulling the plugs, grounding the body, and checking the gap for a good spark. Something may have failed in the magneto.
