Clutch on JD 60
Lauren
09-20-2007 10:35:17
I'm putting new clutch disks in my 1954 JD 60, I was told I need to remove the bearing and grease it with high temperature grease. The manual I have shows the bearing behind the inner clutch disk, but when I remove that all I see is the inside of the belt pulley. Do I need to remove the pulley to grease the bearing and how do I remove it, anyones help would be appreciated, thanks.
JOHN DEERE 70
09-20-2007 11:09:45
 Re: Clutch on JD 60 in reply to Lauren, 09-20-2007 10:35:17
TO PULL THE BELT PULLEY OFF .YOU NEED TO TAKE THE FORK OUT BY TAKING THE FOUR BOLTS OUT WHERE THE PULLEY BRAKE IS TO REMOVE THE ASSEMBLY.
JOHN DEERE 70
09-20-2007 11:09:39
Lauren
09-20-2007 10:49:16
I do have the driver disk removed but don't know how to remove the pulley.
Lauren
09-20-2007 10:49:12
machinery-man
09-20-2007 10:48:13
The clutch driver also has to be timed when reinstalling. Look for the crowfeet marks before removing..there is a mark on the shaft and one on the driver. Also becareful, use the correct puller or you will damage/break the driver...
RobMD
09-20-2007 10:41:27
One of the clutch disks in fact, IS behind the inner clutch driver disc. You have to pull this disc off with a puller and then remove the belt pulley as a unit. The bearing is in there, you don't have to remove it to grease it, just pack it right in there.
BEFORE you do any of this, it's probably wise to see if your bearing is wore out!! With the pulley still on the tractor, try picking up and down on the pulley. If you feel a little bit of up and down movement, replace the bearing!!
