Gas pouring out carb.
hunter
01-25-2000 15:31:51
Hey fellars, got one for you. have had my carb. rebuilt 3 times on my 1010 by 2 different mechanics. i walked 2 miles in the wind and snow to pick her up today and it cut off twice before i got home. finally got here cut it off and about an hour later went back out and found gas running out the throat. gotta be a fix somewhere or shes gone.
clooney
01-26-2000 13:46:33
 Re: gas pouring out carb. in reply to hunter, 01-25-2000 15:31:51
Hunter, just a thought, do you have a new & clean fuel filter in it? If your filter isn't working or is missing maybe dirt is gitting to the needle & seat.
KEDDANO
01-25-2000 18:48:04
CLOONEY'S RIGHT ON,FIRE THE BAD MECH. THE ONLY THINGS THAT CAN MAKE GAS FLOW LIKE THAT IS WHATS BEEN SAID,PS..AT LEAST YOU DIDN'T HAVE TO WALK UP HILL BOTH WAYS IN THE SNOW,GET A MANUAL AND TACKLE IT YOURSELF,CARBS ARE NOT THAT TOUGH TO TAKE APART,GOOD LUCK AND LET US KNOW IF YOU NEED MORE HELP,DAN
clooney
01-25-2000 15:51:45
Hunter, if you don't get it repaired soon she definitly will be gone! It sounds like you need a new mechanic. If you put a new needle & seat,float, & set the float level,then check the vent in the fuel tank for being plugged, you can probably keep it.
