4020 Diesel melt down
J Kemp
09-19-2007 18:25:12
The wiring melted down that crosses the bell housing .. After finding the culprit and replacing same, There appears to be no other damage to wiring ,,However I cannot get any Electric Through Anywhere , Is there A fuse or circuit breaker that I should Check ? Thank you
lonzo
09-21-2007 00:19:41
 Re: 4020 Diesel melt down in reply to J Kemp, 09-19-2007 18:25:12
I wish i could see this rig, they came out with 24 volt and some have been changed over to 12 volt and no telling what is the problem. The plug in that is under the hood and in front of dash can give you fits, unplug and have a look see. there could be 2 circuit brakers mounted beside the starter solenoid. Say, do you have any oil and charging lights ?
j kemp
09-22-2007 12:56:08
 Re: 4020 Diesel melt down in reply to lonzo, 09-21-2007 00:19:41
Thanx Lonzo for Your Concern ..... .4020 is now At STABLE 1 ,A .O K . Loose wire hiding from me,, Got a converted 12 volt system now for 2 years , 24 volt was a real NIGHT MARE
lonzo
09-19-2007 21:53:59
Is the 4020 a late or early model?
j kemp
09-20-2007 05:21:33
 Re: 4020 Diesel melt down in reply to lonzo, 09-19-2007 21:53:59
1966
