Diesel 1020 gradually dies
Wilsonfire
09-19-2007 10:06:58
Just bought a 1973 JD 1020 W/loader diesel last week after trying and checking it out throughly, or so I thought. I ran the fuel on the low side, filled it up. After piling up about 8 Yards of sand the tractor now loses power after running for 10 minutes or so and eventually dies. It will always restart usually with full power. I"ve changed filters, cleaned the bowl, and put a highly recommended agent in the tank. It helped. Some. Now what do I check ?
Wilsonfire
09-20-2007 16:51:52
 Re: Diesel 1020 gradually dies in reply to Wilsonfire, 09-19-2007 10:06:58
Thanks for all the ideas - here"s what happened. I ran it until it died, about 15 minutes from cold. Disconnected the return fuel line and it started right up and ran stronger than when purchased. I was so happy I kept running it for 35 minutes varying the rpm every so often but running at full throttle quite a bit. The hydraulics worked like a new one barely pulling the rpm down, temp staying where it should. I put it back together, cleaned up the mess and ran the tractor another 30 minutes. It ran perfectly. Later today I worked it and drove for well over an hour with no hiccups and full power. I"m not looking this gift horse in the mouth but what did I do?
jdemaris
09-19-2007 17:41:00
Check the obvious first - if not done already.
Bleeding is NOT an issue- the system can -and will bleed itself. Make sure the fuel-fitting coming out of the tank isn't clogged, and make sure the fuel pump is working. When checking the fuel pump - only check it by cranking the engine - don't check it by using the hand-primer (if it has one). It's very likely the fuel injection pump has a shattered weight-retainer ring in the governor - if your 1020 has the rectangular JDB or DB pump (not the round C pump). That is very common. When it comes apart, little bits of plastic get caught in the return-fuel fitting on top of the pump. When that happens, the engine will slowly lose power, and finally quit. Then, it will easily start right up again - and then - die again, etc. , &c. An easy check is to remove the fitting. It's where the return-fuel line connects on top of the pump (between the pump and injector-return lines). The fitting is two parts. Remove the entire thing so an open 1/8" pipe-thread-hole is left exposed on top of the pump. Then try running it (fuel will spill out though). If it now runs fine - then you know the problem.
johns48jdb
09-19-2007 15:34:03
you may have an obstruction inside the fuel tank its self. you could also not have a vented fuel cap. leave it loose or run it without the cap and see what happens. some guys working for me lost my fuel cap and stuffed paper towels in the hole. the got soaked and fell into the tank. every now and then they would settle to the bottom of the tank and shut the fuel off. if there is any rubber hose in the supply line it could be breaking down from the inside and shutting off the flow of fuel.
RobMD
09-19-2007 11:12:11
Is there ANY ~OTHER~ FILTER FROM THE FUEL LINE TO THE TANK? If so, remove this filter. I had one on a 2155 that I overlooked, it was doing the same thing that your tractor is doing, STARVING FOR FUEL. I found that a small tiny filter was plugging up the line, I removed this useless tiny filter. (NOT the MAIN filter!!!)
Brian Bell
09-19-2007 10:23:52
You didn't run it out of fuel did you? Be sure you didn't miss any filters anywhere. You may also need to bleed the injectors/pump as there may be some trapped air in there. I'm not a big JD person, but a diesel is a diesel.
