Decal placement for b ?
two cylinders s
09-18-2007 15:40:06
Im finally getting to the point where i might be able to put some decals on this 48 b. I got location for hood grill and i know the deere is centered on front of batt. box . I need to know air cleaner if i could get a measurement up from the clasping ring up to where it should be? Pto warning goes in the middle of gaurd? warning drive slow ? I dont know the pulley local either if i could get a measurment from the outer edge to how far in it goes ? Thks for the help guys almost done with this money pit.
Mike Aylward
09-20-2007 05:50:53
 Re: Decal placement for b ? in reply to two cylinders saves gas, 09-18-2007 15:40:06
TCSG, there is no decal on the belt pulley of your B. It appears you must have a generic decal set. This decal is not used. Mike
Gary from Muleshoe
09-19-2007 10:05:37
B1567 R Donaldson air cleaner service decal on air cleaner body. Yellow background framed in green. Reads as follows: SERVICE EVERY 30 HOURS More frequently under severe dust condition remove oil cup, empty oil, and scrape out dirt,. Refill to oil level bead with same viscosity oil recommended for engine crankcase for prevailing temperatures. See operator manual.
No measurement given for this.
Pto warning goes in the middle of guard? Yes
Warning drive slow? Not mentioned in this book.
I don�t know the pulley local either if i could get a measurement from the outer edge to how far in it goes? This also is not mentioned in this book. I have notice on the ones I have seen that they are lined up on the outer edge of the cover.
I hope this helps, I got this information from the John Deere Tractor Data Book, written by Lorry Dunning.
Gary from Muleshoe
09-18-2007 19:25:45
I have a book at my work that tells the locations of decals. I will look tomorrow and get back with you.
09-18-2007 16:39:45
P.S i asked jorde about there location ,he didnt know them off the top of his head. He said he had a book full of many models decal locations that he was going to publish but he loaned it to someone and it (got lost). I told jorde how popular he is on our forum. He said hes very flatterd about all the good comments but he doesnt get into them dangfangld computers its too confusing lol.
