4010 Diesel Electrical
Tom Bateson
09-17-2007 17:25:37
Currently working on a neighbors 4010 Diesel that has electrical problems. One of which is too many people changing things over the years. I normaly work on the red equipment and as such do not have a lot of knowledge or manuals on the Green line of equipment. Is there a good source some where other than buying a John Deere manual for the electrical schematics and wiring digrams? I purchased on of the IT Series manuals and it has a basic drawing and information but not a lot of detail.
ET
09-18-2007 08:59:34
 Re: 4010 Diesel Electrical in reply to Tom Bateson, 09-17-2007 17:25:37
Is it still the 24 volt system or has it been butchered into a 12 volt system? If its been changed factory wiring diagrams won't be much help.
Tom Bateson
09-18-2007 17:54:59
 Re: 4010 Diesel Electrical in reply to ET, 09-18-2007 08:59:34
ET: Fortunately it is still a 24 volt system. What gauge wire is called for from the positive batery post to ground on the left battery? Currently there is a 10 gauge wire which seems way to small for what I am use to seeing.
Thanks
ET
09-19-2007 05:34:36
 Re: 4010 Diesel Electrical in reply to Tom Bateson, 09-18-2007 17:54:59
That wire is a fuse wire so it is suposed to be small. The 24 volt system is completle insulated from the two 12volt systems. One positive ground and one negative ground. They both ground through that fuse wire you asked about. The color of the wires for each side of the system is blue and brown, I don't recall the polarity of each color. Each side runs half the dash and half the headlights. You can take the endcap off the starter right on the tractor and see how worn the brushes are, and make sure the brush dust is not piled up and shorting to the 24 volt starter stuff.
Tom Bateson
09-19-2007 11:44:06
 Re: 4010 Diesel Electrical in reply to ET, 09-19-2007 05:34:36
ET;
Again Thank you, the starter and generator are out being rebuilt as there were problems with both. Recieved a call today staing they are ready for pick up. Hopefully I will get this one finished tonight.
Jill.M
09-17-2007 18:37:06
Might also try this site for John Deere books and manuals
http://www.findtoolsnow.com/tractor_manuals_and_books.html
rvirgil_KS
09-17-2007 18:00:49
Check these
Link
24 volt wiring diagrams
Link
discussion of 24 volt
Bob
Tom Bateson
09-18-2007 07:29:49
 Re: 4010 Diesel Electrical in reply to rvirgil_KS, 09-17-2007 18:00:49
Jill / Bob:
Thanks for the help and information.
